PF Golf 2 motor i 1,6 Caddy 1... indlæg om ombygning {{forumTopicSubject}}
Er ved at ligge en Golf 2 pf motor i min caddy 1
her vil jeg ligge diagrammer og diverse løsninger i forbindelse med ombygningen
CE1 sikrings box pin out
http://www.a2resource.com/electrical/CE1.html
Relæ oversigt ( nummer på relæ )... hvis i kender flere skal i være velkomne til at byde ind.. skal gerne opdatere listen løbende
1 = carb inlet manifold heater
2 = fuel pump (MK1 & Early MK2/Rocco K-Jet, no rev limiter)
5 = shift light and MPG gauge
17 = x-over relief (disables most ign live items while engine turning on starter motor)
18 = x-over relief (disables most ign live items while engine turning on starter motor)
19 = front wiper intermittant
20 = rear wiper non-intermittant (when you push the stalk forward, it'll only wipe once, no intermittant!)
21 = hazard/indicator
23 = switched relay, often used for electric windows
24 = switched relay, often used for horn or fogs on older models
30 = MK3 (GTI 8v or 16v?) ECU
31 = 'time control unit' fan control (fan after run)
32 = MK2 digifant ECU
33 = headlight washers
36 = headlights on warning (possibly seatbelt too?)
42 = coolant level sensor control (pre-90 & digifiz dash)
43 = coolant level sensor control (pre-90 & digifiz dash)
53 = misc equipment ignition switched (horn, fogs, leccy windows etc)
57 = k-jet 8v idle speed control relay
61 = decelleration cut-off for carb models
62 = fuel pump (Later MK2/Rocco/Cabby K-Jet, built in rev limiter)
67 = fuel pump (MK2 digifant, 16v and MK3 models)
72 = rear wiper intermittant
79 = ABS system relay
80 = fuel pump (MK2 digifant, 16v and MK3 models)
83 = control unit for syncro freewheel lock
90 = fuel pump after run control unit
99 = front wiper variable intermittant
103= glow plug
104= glow plug
109= early VR6 ECU relay
133= aircon
147= aircon
150= starter motor
167= fuel pump (MK2 digifant, 16v and MK3 models)
174= rear wiper
179= ABS control unit relay
191= hazard/indicator
192= intermittant wash/wipe for models w/rain sensor
204= 40a, fog lamp, electric fan etc. pinout compatible to 53
213= fan, assume radiator?
370= fan, assume radiator?
372= fuel pump relay, 97-05 Passat
389= intermittant wash/wipe
407= rear petrol flap
409= fuel pump relay, 02 Golf
644= x-over relief (disables most ign live items while engine turning on starter motor)
jan 2008
Følger: 8 Følgere: 8 Biler: 3 Emner: 2 Svar: 7
Num. Relay/Pin
1 Digifant ECU
1 Main Fusebox Ground
2 Main Fusebox Battery Power
3 Digifant ECU
4 Main Fusebox Start/Run Power, Fuse 17
2 Fuel Pump (Jetronic/K-Jetronic)
3 Fuse 5 (Fuel Pump)
5 Ignition Coil Pin 1 (Tachometer)
6 D13 (not used)
7 Main Fusebox Starter Power (not used)
8 B6 (not used)
2 Fuel Pump (KE-Jetronic/Digifant)
1 Main Fusebox Ground (not used)
5 Ignition Coil Pin 1 (Tachometer) (not used)
6 Jetronic/Digifant ECU (fuel pump turn-on)
8 B6 (not used)
2 Glow Plug
3 Glow Plugs
5 Tachometer (not used)
6 Engine Oil Temperature Sender
8 Glow Plug Light
2 Inlet Manifold Pre-Heater (Carb, Europe only)
3 N (Inlet Manifold Pre-heater)
4 Main Fusebox Start/Run Power (not used)
6 Automatic Choke
8 B6 (not used)
3 Seat belt Warning
1 Seat Belt Switch
2 K02
3 Key In Power
4 Door Switch, Seat Belt Switch
5 Main Fusebox Start/Run Power
6 Main Fusebox Ground
7 Seat Belt Light
4 Upshift Indicator (4)
1 Ignition Coil Pin 1 (Tachometer)
2 A27
3 Upshift Light
5 Transmission Switch
7 Upshift Vacuum Switch
5 Air Conditioner
2 A/C Switch
3 Fan Switch High Speed
4 Main Fusebox Battery Power, Fuse 1
5 Radiator Cooling Fan
6 Fresh Air Fan
7 A/C Clutch (via pressure and temperature switches)
8 Battery, Fuse 23 (30A)
6 Dual Horn (1-3 jumper on models with single horn)
1 L4 (Horn Button)
2 L3 (ground)
3 L2 (Horns)
4 L1 (Main Fusebox Start/Run Power, Fuse 18)
7 Fog Lights
2 Main Fusebox Run Power
3 B20
4 Headlight Switch Pin 58 (Park. Lights)
8 Load Reduction Relay
3 Main Fusebox Run Power
4 B10 (Ignition Switch Run Power)
9 Fuse Holder
10 Wiper/Washer
1 Intermittent Switch
2 Wiper Motor Low Power
3 Main Fusebox Run Power, Fuse 11
4 Main Fusebox Ground
5 Wash Switch
6 Wiper Switch Park/Low Signal (positive when moving/low, ground when parked/off)
11 Rear Wiper
1 Wiper Switch Wipe/Wash Signal
2 Rear Wiper Motor
3 Main Fusebox Run Power, Fuse 12
12 Flashers
1 Flasher Input
2 A11 (Trailer Light)
3 Flasher Output
Fuses:
Num. Fuse Power Rating
1 Radiator Cooling Fan Main Fusebox Battery Power 30A
2 Brake Lights Main Fusebox Battery Power 10A
3 Cigarette Lighter, Radio, Power Antenna, Amplified Speakers, Gauge Cluster (Clock, MFA) Main Fusebox Battery Power 15A
4 Hazard Lights Main Fusebox Battery Power 15A
5 Fuel Pump, Carb. Preheat (Europe only) Fuel Pump Relay Pin 3, Output 10A
6 Fog Lights Fog Light Switch 15A
7 Parking Lights (Left) Headlight Switch Pin 58 (Park. Lights) 10A
8 Parking Lights (Right) Headlight Switch Pin 58 (Park. Lights) 10A
9 High Beam Headlight, Right, Indicator Light High Beam Switch Pin 56b (High Beam) 10A
10 High Beam Headlight, Left High Beam Switch Pin 56b (High Beam) 10A
11 Front Wiper/Washer Main Fusebox Run Power 15A
12 Rear Wiper Park Switch, Water Separator Sender (diesel), Remote Control Mirror Switch, Power Window Relay, Heated Seat Control Units Main Fusebox Run Power 15A
13 Rear Window Defogger, Heated Side Mirrors Main Fusebox Run Power 15A
14 A/C Switch, Fresh Air Fan Switch, Glove Compartment Light Main Fusebox Run Power 20A
15 Back-Up Light Switch, Auto. Trans. Console Light, Radiator Fan After-Run Control Unit Main Fusebox Start/Run Power 10A
16 Horns Main Fusebox Start/Run Power 15A
17 Knock Sensor Control Unit, Oxygen Control Unit, Throttle Switches (CIS-E), Digifant ECU Relay Main Fusebox Start/Run Power 10A
18 Horn Button, Low Coolant Level Control Unit, Idle Boost Control Unit, Oxygen ECU, Idle Stabilizer Relay, Cruise Control Switch, Heated Washer Jets, Differential Lock (Quantum), Seat Belt and Brake Warning Light power (Cabriolet and Scirocco) Main Fusebox Start/Run Power 15A
19 Hazard Switch, Turn Signal Switch, Seat Belt and Brake Warning Light (Golf and Jetta) Main Fusebox Start/Run Power 10A
20 License Plate Lights, Luggage Compartment Light (Cabriolet), Headlight Washer Relay (Europe only) Headlight Switch Pin 58 (Park. Lights) 10A
21 Headlight, Low Beam, Left High Beam Switch Pin 56 (Low Beam) 10A
22 Headlight, Low Beam, Right High Beam Switch Pin 56 (Low
jan 2008
så skulle det være til at finde frem til det man skal bruge
der kommer også et på CE2 (nyere golf 2 og 3er )
