822 visninger
Carsten a.k.a. Fister®
29. jun 2007 Følger: 23 Følgere: 30 Biler: 11 Emner: 296 Svar: 1.328
Alfa 156 JTS Fejlkode ( motorsymbol) {{forumTopicSubject}}
Kørte roligt derud af og "fiflede" lidt med infodisplayet da motorsymbolet pludselig begyndte at lyse og Infodisplayet skrev at jeg skulle køre på værksted...
Den kører jævnt og fint som den skal. Den bruger ikke mere benzin og den starter og lyder også fint...???
Nogen gode ideer ? Kan jeg evt. selv "nulstille" fejlmeddelelsen ?
My GT 2.0L JTS has been idling a bit rough recently, and it felt like a few of my horses had flown south for the winter. In addition, my climate insisted on only blowing hot air, no matter what temp I dialled in.
Having trawled through various threads, the ECU reset fix was mentioned several times as a cure for both symptoms.
So, today being a quiet day in the Christmas break, I decided to attempt the ECU and throttle re-set procedure -which is as follows if you haven't seen in other threads :
1. Disconnect battery for 45 mins
2. Reconnect battery, and turn ignition to MAR for 90 secs
3. Turn off and leave 90 secs
4. Start engine WITHOUT pressing throttle and let the car idle for 15 mins (I repeat, do not touch the throttle whilst the car is idling)
5. Turn engine off and leave for 10 minutes
6. Start the car and go for a drive, using a number of styles (eg town, motorway, thrash etc)
So I did this, and my GT is reborn ! Faster, smoother, more torqier, even idle - it's bloody fantastic ! I can't believe how different the whole car feels.
Kørte ud til min mekaniker og fik en udlæsning. Det var et "fejlsignal" fra en lambdasonde (Nr. 1 - box 1 ?)
Fejlen blev slettet og er ikke kommet igen
