E30 Historie(Eng) {{forumTopicSubject}}
BMW E30 3 Series
The E30 3 series was introduced at the end of 1982. It came available in 1983.
It was available as 316, 318i, 320i and 323i. The 320i and 323i where six cylinders
and had a check control and rev counter as standard. At the end of 1983 a 4 door
version came available. In 1985 some changes were made to the 3 series. First the
320i received a new engine that now had 129 HP. Then the 324d was introduced.
It was the first 3 series diesel ever. It had a six cylinder diesel engine with 86 HP.
Also new where the 325i, 325e, 325ix and 325i convertible. The 325i replaced the
323i and had 170 HP. The 325ix had four wheel drive and the 325i convertible was
the first convertible that was made made by BMW. All models received a very small
facelift. The front spoiler was changed. In 1987 the 324td was introduced. It had a
six cylinder diesel engine with turbo wich now had 115 HP. This was also the year
that the 3 series received a facelift. Black plastic bumpers replaced the chrome
ones and the rear lights where bigger now. The 318i received the new M40 four
cylinder engine. The 316 received the old 318i engine and now had 102 HP. In 1988
the 316i received another new engine. It now had a M40 engine wich had 100 HP.
Also available now was the new Touring. It was available as 320i, 325i, 325ix and
the 324td. In 1989 the 318is came available and the 318i was available as touring.
The 318is had a 16 valve engine that produced 136 HP. In 1991 the 316i touring
came available. This was also the year that the convertible received the same
facelift as the sedan had in 1987. There was also a 318i convertible introduced.
This was also the last year that the E30 sedan was available. The new 3 series
was allready available since the end of 1990 so the old E30 went out of production.
The Convertible was available until 1993 and the four cylinder tourings until 1994.
jul 2006
Følger: 285 Følgere: 198 Biler: 8 Emner: 67 Svar: 157
jul 2006
Bmw E30 3 Series
El E30 3 series fue introducido a finales de 1982. Vino disponible en 1983. Estaba disponible como 316, 318i, 320i y 323i. El 320i y el 323i donde seis cilindros y tenían un control del cheque y una revolución contrarios como estándar. A finales de 1983 una versión de 4 puertas vino disponible. En 1985 algunos cambios fueron hechos a las 3 series. Primero el 320i recibió un motor nuevo que ahora tenía HP 129. Entonces el 324d fue introducido. Era las primera 3 series del diesel siempre. Tenía un motor diesel de seis cilindros con HP 86. También nuevo donde el convertible 325i, 325e, 325ix y 325i. El 325i substituyó el 323i y tenía HP 170. El 325ix tenía impulsión de cuatro ruedas y el convertible 325i era el primer convertible que fue hecho hecho por BMW. Todos los modelos recibieron una cirugía estética muy pequeña. El interceptor aerodinámico delantero fue cambiado. En 1987 el 324td fue introducido. Tenía un cilindro seises que el motor diesel con el wich de turbo ahora tenía HP 115. Éste era también el año que las 3 series recibieron una cirugía estética. Los topes plásticos negros substituyeron el cromo unos y las luces de la parte posterior donde más grandes ahora. El 318i recibió el motor nuevo del cilindro M40 cuatro. Los 316 recibieron el viejo motor 318i y ahora tenían HP 102. En 1988 el 316i recibido otro motor nuevo. Ahora tenía un wich del motor M40 tenía HP 100. También disponible ahora estaba el nuevo viajar. Estaba disponible como 320i, 325i, 325ix y el 324td. En 1989 el 318is vino disponible y el 318i estaba disponible como viajando. El 318is tenía un motor de 16 válvulas que produjo a HP 136. En 1991 el viajar 316i vino disponible. Éste era también el año que el convertible recibió la misma cirugía estética que el sedán tenía en 1987. Había también un convertible 318i introducido. Éste era también el año pasado que el sedán E30 estaba disponible. Las nueva 3 series estaban disponibles allready desde finales de 1990 así que el viejo E30 salió de la producción. El convertible estaba disponible hasta 1993 y los cuatro tourings del cilindro hasta 1994.
E30 Historie(Eng)
