Kommentarer på:  insp. i display på golf 3 tdi
  • #1   27. jan 2011 here ya go...
    turn the ignition to the on position, check that the mileage meter is set and not on the trip...press and hold the button on the left...while holding, turn the ignition to off (do NOT take out the key) and release the button...the letters OEL should pop up in the same spot your seeing IN 02...now, on the right side buttons (clock time buttons) press the bottom button as many times as it takes until it changes from OEL to IN 02, when you get there, press the same button and hold it down until ----- is displayed....then your done for that one...turn the key wait until IN 00, OEL, IN01 or IN02 appears then turn the key off again...if something else appears (ie. IN01 or OEL) repeat the process until its all cleared....when it says IN00 everything is reset at its at the default "no service required" flash
  • #2   27. jan 2011 takker smiley
  • #3   2. feb 2011 er det samme måde på en benziner ?:)
