1.434 visninger | Oprettet:
Columbus radio/navigation.. {{forumTopicSubject}}
Hey..
Har sådan en fætter monteret i min Octavia..
Kæresten og jeg sad og snakkede lidt om at det kunne være fedt og proppe en skive i med musikvideoer fremfor en skive med mp3 filer..
Men uanset næsten hvordan jeg får fixet den skive, så viser den fejl og at jeg skal checke min cd/dvd, hvorefter den spytter den ud igen..
Hvilket filformat skal jeg have filerne i inden jeg brænder dem på skiven for at den kan afspille dem i afspilleren..?
På forhånd tak..
  • Grave 205 kr.
Kommentarer på:  Columbus radio/navigation..
  • #1   8. mar 2011 General information for CD/DVD operation
    Audio-CDs (CD-A) and Audio-DVDs, MP3-CDs and MP3-DVDs as well as Video-
    DVDs can be played in the internal CD/DVD drive.
    CD not legible
    If the unit cannot read an inserted CD/DVD, “CD fault will be displayed for a short
    period of time. Please check the CD.” or “incorrect data format. Data cannot be
    read.” and the CD/DVD is reinserted into the initial position after a few seconds.
    If the CD/DVD is not taken out within 10 seconds, it is drawn in again for safety
    reasons.
    WARNING
    • The CD player is a 1st class laser product. There is a definite risk of injury
    from invisible laser beams if it is opened.
    • The CD player contains no parts that have to be serviced or repaired.
    Please contact your specialist garage if a mechanical defect occurs or the CD
    player has to be repaired.
    Caution
    • Inserting a second CD/DVD while a CD/DVD is being ejected can destroy the
    CD/DVD drive in the unit. Please note that the CD/DVD ejection lasts a few seconds
    after pressing the Eject key During this time the lock in front of the CD/DVD
    case is open. It is essential that you wait until the CD/DVD has been fully ejected
    before you try to insert a new CD/DVD.
    • If the CD/DVD drive becomes mechanically defective or a CD/DVD has been
    inserted incorrectly or not fully, “CD fault will be displayed. Please check the CD.”
    and then the “DVD drive the fault” indicated on the touch-screen. Please check
    the CD/DVD and place it again correctly and fully into the drive. If a “DVD drive
    fault” is indicated again, please contact your Škoda dealer.
    • If the inside temperature of the unit is too high, no CDs or DVDs will be
    accepted. The unit switches into the last active operating mode.
    Note
    • If the function key is inactive, no new Audio CD/DVD has been inserted or
    an inserted Audio CD/DVD is not readable.
    • It is possible that CDs protected by copyright and self-made CD-R, CD-RW and
    DVD-RWs are not returned at all or only in certain circumstances.
    • WMA audio data (Windows Media Audio) can also be replayed by the unit and
    stored on the hard disk (HDD) providing this has not been protected by the DRM
    procedure copyright (Digital Rights Management). The operation and behaviour of
    the unit complies with the MP3 compressed audio data and are not described
    further.
    • Please observe the following information for the MP3 operation ⇒ page 26.
    • Please comply with the national legal copyright requirements in your country.
    • The DVD drive installed into this unit uses a Dolby Digital® Audio coding system
    and MLP Lossless® for highest reproduction quality even with standard Audio
    DVDs. “Dolby®”, “MLP Lossless®” and the Double-D-Symbol are trademarks of
    Dolby Laboratories®.
    • With the help of “DTS®” and “DTS 2.0®” the surrounding sound of a DVD is
    transformed and replayed in best stereo quality. “DTS®” and “DTS 2.0®” are registered
    trademarks of DTS, Inc.
  • #2   8. mar 2011 der står intet om et format du skal bruge så det er bare at prøve dig frem.
  • #3   8. mar 2011 Har fundet brugsforvirringen på dansk..
    Men ja.. Så langt kom jeg også.. Men uanset hvilket filformat jeg valgte, ville den kun sige at der var en fejl og jeg derfor skulle cheke min cd/dvd..
  • #4   8. mar 2011 har du prøvet med en normal dvd film og set om den virker ?
  • #5   8. mar 2011 Den virker fint når man holder stille.
  • #6   8. mar 2011 så er det, det automatiske beskyttelsessystem for ikke at blive distraheret der kommer ind i billedet...
  • #7   8. mar 2011 Prøv at trække håndbremsen 1 klik smiley
  • #8   8. mar 2011 Parker:
    Nej.. For da jeg smed den skive i hvor jeg havde lagt nogle musikvideoer på, sagde den fejl..
    Kan godt smide en film i og køre.. Får dog kun lyd og sort skærm..
