Kommentarer på:  Oversigt over tandrem Peugeot 206 2,0 hdi
  • #1   30. nov 2016 Kan det bruges?
  • #2   30. nov 2016 How to Replace timing belt on Peugeot 2.0 HDi
    Published June 30, 2015
    Replacement Interval Guide
    Special Tools
    Auxiliary drive belt tensioner tool – Peugeot Nos.(-).0188.Z/Q1.
    Camshaft sprocket locking tool – Peugeot No.(-).0188.M.
    Crankshaft reluctor puller – Peugeot No.(-).0188.P.
    Crankshaft sprocket centralizing tool – Peugeot No.(-).0188.AH.
    Flywheel timing pin – Peugeot No.(-).0188.X.
    Flywheel locking tool – Peugeot No.(-).0188.F.
    Tensioner pulley locking pin – Peugeot No.(-).0153-AL.
    Special Precautions
    Disconnect battery earth lead.
    DO NOT turn crankshaft or camshaft when timing belt removed.
    Remove glow plugs to ease turning engine.
    Turn engine in normal direction of rotation (unless otherwise stated).
    DO NOT turn engine via camshaft or other sprockets.
    Observe all tightening torques.
    How to Replace timing belt on Peugeot 2.0 HDi 2005-2007
    Removal
    Raise and support front of vehicle.
    Remove:
    Engine top cover.
    Engine undershield.
    RH front wheel.
    RH splash guard.
    Auxiliary drive belt. Use tool Nos.(-).0188.Z/Q1.
    Scuttle panel.
    Support engine.
    Remove:
    RH engine mounting bolts [1] .
    RH engine mounting.
    RH engine mounting intermediate bracket bolts [2] .
    RH engine mounting intermediate bracket.
    Disconnect fuel pipes from timing belt upper cover.
    Remove:
    Timing belt upper cover [3] .
    Turbocharger air hoses.
    Subframe reinforcement plate (if fitted).
    Lower engine steady bar.
    Turn crankshaft clockwise to TDC on No.1 cylinder. Ensure camshaft sprocket timing hole at 4 o’clock position [4] .
    Insert:
    Camshaft sprocket locking tool [5] . Tool No.(-).0188.M.
    Flywheel timing pin [6] . Tool No.(-).0188.X.
    Fit flywheel locking tool [7] . Tool No.(-).0188.F.
    Remove:
    Crankshaft position (CKP) sensor.
    Crankshaft pulley bolt [8] .
    Crankshaft pulley [9] .
    Timing belt lower cover [10] .
    Reluctor [11] . Use tool No.(-).0188.P.
    NOTE: Ensure reluctor is not damaged.
    Slacken tensioner pulley bolt [12] .
    Turn tensioner pulley away from belt. Use Allen key [13] .
    Insert tensioner pulley locking pin [14] . Tool No.(-).0153-AL.
    Remove timing belt.
    Installation
    Check tensioner pulley and guide pulley for smooth operation.
    Check water pump sprocket for smooth operation.
    Check crankshaft sprocket has free movement on keyway.
    Ensure flywheel locking tool located correctly [7] .
    Ensure flywheel timing pin located correctly [6] .
    Ensure camshaft sprocket locking tool located correctly [5] .
    Ensure tensioner pulley locking pin located correctly [14] .
    Centralize crankshaft sprocket. Use tool No.(-).0188.AH [15] .
    Fit timing belt in following order:
    Crankshaft sprocket.
    Guide pulley.
    Camshaft sprocket.
    Water pump sprocket.
    Tensioner pulley.
    Ensure belt is taut between camshaft sprocket and guide pulley.
    Remove locking pin [14] . Finger tighten tensioner pulley bolt [12] .
    Turn tensioner pulley anti-clockwise until pointer at maximum setting. Use Allen key [13] .
    Tighten tensioner pulley bolt [12] . Tightening torque: 21 Nm.
    Remove tool [15] .
    Install:
    Reluctor [11] .
    Tighten crankshaft pulley bolt [8] . Tightening torque: 50 Nm.
    Remove tools [5] , [6] & [7] .
    Turn crankshaft four turns clockwise.
    Install:
    Flywheel locking tool [7] .
    Remove:
    Hold tensioner pulley in position. Use Allen key [13] .
    Turn tensioner pulley clockwise until pointer aligned with notch [16] & [17] . Use Allen key [13] .
    NOTE: If pointer passes notch [17] , repeat tensioning procedure.
    Install:
    Coat crankshaft pulley bolt with suitable thread locking compound.
    Install:
    Tighten crankshaft pulley bolt [8] . Tightening torque: 70 Nm + 62°.
    Check torque setting of crankshaft pulley bolt is 260 Nm.
    Install components in reverse order of removal.
    Tighten RH engine mounting intermediate bracket bolts [2] . Tightening torque: 60 Nm.
    Tighten RH engine mounting bolts [1] . Tightening torque: 60 Nm.
  • #3   30. nov 2016 Mange tak smiley
    Hold da kæft en smøre jeg skal skifte tandrem ikke bygge en raket motor smiley
