8.443 visninger
Big block vs small block {{forumTopicSubject}}
Hey, sad lige og funderede over, hvad betydningen af big block i small block/big block forbindelse egentlig dækker over. Cylindervolumen oder? Er ikke så stærk i de amerikanske musclecar-begreber ; )
aug 2003
Følger: 2 Følgere: 1 Emner: 58 Svar: 560
aug 2003
og at small block er 5.0 liter V8
men er ikke helt sikker
aug 2003
http://www.bilgalleri.dk/html/gal_visbil.asp?ID=12737
de har begge big block motore men 2 forskellige cylindere volumer, så mon ikke jeg skal holde min kæft og lade dem der ved noget om det, udtale sig......
aug 2003
ups, den her i stedet
dec 2003
Følger: 50 Følgere: 48 Biler: 14 Emner: 132 Svar: 844
dec 2003
dec 2003
The small block chevy came out in 1955 at 265 cubic inches, it grew in later years to 283, 302, 305, 307, 327, 350, 400, and shrunk to 262 and 267. the small block is just that, small, at the time it was very compact for it`s size and made better power than expected, it has a excellant oiling design, and 5 bolts per cylinder to retain the head. the big block chevy came out in the early 60`s, they are 396, 402, 427, 454. the big block has bigger everything than the small block, the block is bigger, crank, heads, intake, etc. they shared the same uses in carbs, distributors and not much else. your engine is a small block. you`ll likely hear also of the 366 and 427 tall deck truck engines, these have taller deck heights and really aren`t meant as performance engines. the small block chevy is considered the winniest and most popular engine in history. however, I`d say that`s debateable to a point.
apr 2004
Følger: 3 Følgere: 2 Emner: 24 Svar: 103
