1.303 visninger
info vedr min camaro??? {{forumTopicSubject}}
jeg har lige købt en camaro men ved ikke en skid om den er der nogen der har en hp hvor man kan se sådan noget det er en z28 5,7L fra 97 har fået afvide at den har 350 hk passer det??
info skal bruges til når den skal oprettes
dec 2005
Følger: 10 Følgere: 9 Biler: 3 Emner: 84 Svar: 1.147
billeder her
feb 2004
Følger: 6 Følgere: 5 Biler: 1 Emner: 13 Svar: 114
Mange af dem går med 450...
Er det en turbo?
apr 2005
Følger: 16 Følgere: 14 Emner: 111 Svar: 2.012
maj 2005
Følger: 129 Følgere: 149 Biler: 8 Emner: 286 Svar: 6.007
dec 2005
der er ikke turbo på
dec 2005
maj 2005
dec 2005
dec 2005
jul 2004
Følger: 9 Følgere: 9 Biler: 5 Emner: 13 Svar: 578
den køre 9,5km/l og køre på 245/50zr16 på 8x16" alu.og den måler 491/189/131cm vægt 1550kg
mvh allan h
maj 2005
dec 2005
Allan H: takker så kom der lidt mere til samlingen
maj 2005
Vehicle Dimensions
Specification 2-door convertible 2-door hatchback
Wheelbase, in. 101.1 101.1
Overall Length, in. 193.2 193.2
Overall Width, in. 74.1 74.1
Overall Height, in. 52.0 51.3
Curb Weight, lbs. 3440 3306
Cargo Volume, cu. ft. 7.6 12.9-33.7
Standard Payload, lbs. -- --
Fuel Capacity, gals. 15.5 15.5
Seating Capacity 4 4
Front Head Room, in. 38.0 37.2
Max. Front Leg Room, in. 43.0 43.0
Rear Head Room, in. 39.0 35.3
Min. Rear Leg Room, in. 26.8 26.8
Specifications Key: NA = not available; "--" = measurement does not exist.
Powertrain Options and Availability
Base engine was a 3.4-liter V6 (an enlargement of the former 3.1-liter), delivering 160 horsepower. Either 5-speed manual shift or a 4-speed overdrive automatic might be installed. Under the Z28's hood lurks a Corvette-based 5.7-liter V8 rated at 275 horsepower (285 horses for '96) and hooked to a 6-speed manual gearbox or optional 4-speed automatic. Unlike the Corvette's drivetrain, the Z28's 6-speed box lacked a forced first-to-fourth gear shift under light throttle in its first season, but added that fuel-economy feature for '94, when the automatic shift gained electronic control. Six-speed cars also got a 3.42:1 rear-axle ratio in 1994, replacing the prior 2.73:1 or optional 3.23:1 ratio. A more powerful (200-horsepower) 3.8-liter V6 arrived in spring 1995 as an option, and was made standard for '96. Engines in specially built SS Camaros in 1996 developed 305 horsepower--20 more than usual. In 1998, Camaro got its own version of the Corvette V8. In Z28, trip the engine made 305 horsepower. With the SS package it made 320 horsepower. V8s gained 5 horsepower in 2001.
Engines Size liters/
cu. in. Horse-
power Torque Transmission:
EPA city/hgwy Consumer Guide®
Observed
ohv V6 3.4 / 207 160 200 4-speed automatic: 19/28
5-speed automatic: 19/28
4-speed automatic: --
5-speed automatic: --
ohv V6 3.8 / 231 200 225 4-speed automatic: 19/29
5-speed automatic: 19/30
4-speed automatic: 18.6
ohv V8 5.7 / 350 275-310 325-340 6-speed manual: 16/27
4-speed automatic: 17/25
6-speed manual: 13.2
4-speed automatic: 17.4
ohv V8 5.7 / 346 305-325 335-350 6-speed manual: 17/25
4-speed automatic: 18/27
6-speed manual: --
4-speed automatic: 15.1
Engine Key: l/cu. in. = liters/cubic inches; ohv = overhead valve; ohc = overhead camshaft; dohc = dual overhead camshaft; I = inline cylinders; H = horizontally opposed cylinders; V = cylinders in a V configuration; W = cylinders in a W configuration; rpm = revolutions per minute; CVT = continuously variable (automatic) transmission; NA = not available; "--" = measurement does not exist.
NHTSA Crash-Test Results
Test 1999 Camaro
Front Impact, Driver 4
Front Impact, Passenger 5
1999 Camaro
Front Impact, Driver --
Front Impact, Passenger --
The National Highway Traffic Safety Administration (NHTSA) tests a vehicle's crashworthiness in front- and side-impact collisions and rates its resistance to rollovers. Front-impact crash-test numbers indicate the chance of serious injury: 5 = 10% or less; 4 = 10-20%; 3 = 20-35%; 2 = 35-45%; 1 = More than 45%. Side-impact crash-test numbers indicate: 5 = 5% or less; 4 = 6-10%; 3 = 11-20%; 2 = 21-25%; 1 = More than 26%. Rollover resistance numbers indicate the chance for rollover when the vehicle leaves the roadway: 5 = Less than 10%; 4 = 10-20%; 3 = 20-30%; 2 = 30-40%; 1 = More than 40%.
Built In: Canada
Drive Wheels: longitudinal front-engine/rear-wheel drive
det var hva jeg li ku finde på denne hjemmeside:
http://auto.consumerguide.com/Auto/Used/reviews/full/index.cfm/id/2007/act/usedcarreviewspecs/
maj 2005
jul 2004
dec 2005
takker for hjælpen
allan: der skulle efter sigende være lavet lidt ved den
dec 2005
nu skal den lige synes og så får jeg taget lidt billeder så den kan komme på BG
okt 2003
Følger: 66 Følgere: 56 Biler: 5 Emner: 273 Svar: 13.979
det er en Camaro SS der har 350 hk ...
okt 2003
dec 2005
min pris er hemmelig men jeg fik den billigt og har købt den ubeset og uden syn
aug 2005
Følger: 19 Følgere: 18 Biler: 2 Emner: 16 Svar: 125
God fornøjelse.
