808 visninger | Oprettet:
Nyt anlæg. {{forumTopicSubject}}
Vil det her give ordenlig bas i min polo (:
Soundstorm EV4000D mono.
# Variable low pass filter: 50 -150Hz
# Variable subsonic filter: 15 - 40Hz
# Variable 0 to +18dB Bass Boost
# Phase shift selector: 0 or 180
# Variable input gain control
# Input sensitivity selector
# Power and protection LED indicators
# Thermal, overload and speaker short protection
# RCA Line Level inputs
# RCA Line Outputs for system building
# Chrome plated RCA connectors and screw terminals
# Remote subwoofer level control
# Frequency response: 20Hz - 250Hz (+/- 3dB)
# Max power 1 ohm 4000W X 1
# Max power 2 ohm 3000W X 1
# RMS power 2 ohm 2200W X 1
# MAX power 4 ohm 2000W X 1
# RMS power 4 ohm 1600W X 1
# Signal-to-noise ratio 105db
# THD at RMS output 0.01%
JBL W12GTi MKII
# Dual Voice coil design (dual 6-ohm, pre-wired as a 3-ohm sub)
# Differential Drive® Design (DDD) motor
# Die-cast vented basket
# Kevlar®-impregnated paper woofer cone
# Nitrile-butylene surround
# Power handling RMS: 700 watts
# Power handling Peak: 4,000 watts
# Sensitivity 91dB @ 2.83V/1m
# Power Handling 700W RMS, 4,000W Peak
# Frequency Response 18Hz ~ 1kHz
# Impedance 3 or 12 ohms
Kommentarer på:  Nyt anlæg.
Nyt anlæg.
