14.743 visninger | Oprettet:
Fjerne selealarm {{forumTopicSubject}}
Er her nogle herinde, som har prøvet dette på en vw, skoda, audi, seat ?
)Turn key to ON/START - within 60 seconds, turn ignition OFF and fasten the driver seat belt.
2)Start engine and wait for the seat belt light to turn off.
3)Within 60 seconds unbuckle/rebuckle the seat belt 3 times - ending with buckled, you will hear a single chime (sometimes this verification chime is slightly different just the same it works to disable the chime).
This confirms you have turned the repeater chimes off. Repeat the sequence or disconnect the battery to restore the reminder function."
Disconnecting the battery will reset the chime and you'll have to do it again!
Kommentarer på:  Fjerne selealarm
Fjerne selealarm
