1.241 visninger
Innovate LC-1 Kit. ? eller Vems wbo2? {{forumTopicSubject}}
står og skal have fat i et bredbånds lambasonde kit, som skal bruges sammen med mega squirt... hviket af disse 2 skal jeg vælge...
lc-1 kit koster ca. 1800 kr.
vems wbo2 koster 1893 kr.
LC-1 kender man jo..
Følger: 22 Følgere: 23 Biler: 6 Emner: 496 Svar: 1.439
jul 2003
Følger: 13 Følgere: 20 Biler: 3 Emner: 35 Svar: 1.444
Medfølger:
- Digital ur til montering i bil. Ø 52mm.
- LC1
- Bosch LSU4.2 lambdasonde
- Serialkabel til PC Tilslutning
- Multifunktions display
- Software CD
- Innovate Motorsports sticker
he LC-1 is a complete wideband controller built in to a sealed cable, to "survive" in an engine compartment, underneath your car, or attached to a motorcycles' frame.
LC-1 Specifications
The LC-1 is a complete wideband controller built in to a sealed cable. It features the same award-winning patented digital measurement principal found in Innovate's LM-1, and includes digital input, output, and 2 programmable analog
outputs. The LC-1 one is more accurate than conventional designs costing many times as much. It's self-calibrating circuitry can compensate for changes in temperature, altitude and sensor condition. The LC-1 is ideal for applications
such as Dynos, Data Acquisition, Standalone ECUs, and Gauges. The LC-1 can be "daisy chained" for cost-effective individual cylinder tuning, and is fully compatible with Innovate's Modular Tuning System.
For owners of a TRIJEKT EFI system www.trijekt.de we do offer a special programming service, free of charge. We do program the required LC-1 settings for you. Just pick the option when ordering.
POWER:
Operating Voltage 9V-25V
Input Current, Operating 0.8A Typical
Input Current, Max 2.5A during sensor-heater warmup
SENSOR: Bosch LSU4.2
MEASUREMENTS:
Lambda 0.6 to Free Air
AFR 8.8 to Free Air (Gasoline - Other Fuels Programmable)
ACCURACY: For Lambda <1 (9-15 AFR) +/-0 .1 AFR
RESPONSE TIME: Free air to Lambda 0.8 (11.7AFR) <100ms
OUTPUTS:
2 Analog 0-5V, 12-bit resolution, >50K Ohm impedance
Innovate Serial Bus 2.0 RS232, 19.2Kb, up to 32-channel
Scope of delivery:
LC-1 lambda controller
Bosch Wideband Sensor LSU 4.2
Serial cable to PC
daisy chain cable to connect other MTS devices
CD ROM with software
( for serial connecting to the LM-1 via log-chain you do need cable #3759 )
